need the coolest switches and labels..
Old Oct 26, 2003 | 06:15 PM
Carpe Diem's Avatar
i spent a 6 hour train ride figuring out what i was going to do for the switches for my cutout, n20, sub, and tcs disable..
i came up with:
a brushed aluminum plate with four toggle switches(cutout, n20, sub, tcs disable) and a master "arm/safe" key switch to put in the glovebox..
going to place the purge and cutout switch in place of where the "camaro" is right above the radio..
and a fatty mushroom style switch to be mounted on the right side of my shifter(kind of "mad max"ey) pointing upwards as a secondary n20 arm..
now the thing is, i have been looking for switches, but i cannot find the cool ones...
the toggle switches are no prob, but i am looking for a 2" mushroom switch that is open when up and closed when down(not the momentary type, contsant on...) and i am looking for a key switch that is when is in safe mode is open, and when in arm mode is closed..(i think i know a place to get that..)
but to have the key switch override the four toggles, i am thinking some sort relay... no idea where to get something for that...
and finally(i know its long...) i would like to get some sort of fighter jet looking "safe" and "arm" plates.. and some similar n20, cut-out, sub, and tcs labels...
i know i put a lot of crap in this post, but if any of you can help with any part of it, please lemme know.... thanks...
josh
Old Oct 26, 2003 | 07:51 PM
97FormulaWS-6's Avatar
first check out nkk switches...
Also check out www.alliedelec.com, www.digikey.com, www.mouser.com for other switches and/or brands to check out. It'll cost you some $$ for the switches your looking for though...
Old Oct 26, 2003 | 08:19 PM
Carpe Diem's Avatar
preciate it dude...
nkk switches rocks!
and the mouser link was the only one that worked for me..
but thanks a load for the links!
josh
Old Oct 26, 2003 | 08:23 PM
JasonD's Avatar
Admin Emeritus
Fixed the links.
Old Oct 26, 2003 | 08:37 PM
Carpe Diem's Avatar
suuuuweeet, thanks!
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
