My new LED Cargo Light. Inspired by InfiniteReality
Re: My new LED Cargo Light. Inspired by InfiniteReality
I have pics of the white setup on my website; however due to conflicts with the Red LED's I was forced to find a new supplier for them. The new ones will arrive shortly, and I will post here as well as my site with comparison pics.
I can tell you the 50 Red 8,000mcd setup that I had built was not a bright as my 24 LED 26,000mcd setup. It was bright; however the amount of usable light is not as good as the WHITE setup. Now I will say that the Red setup does provide a great Red appearance lighting for the interior.
and 24 times 26000=624,000
I was wondering if all the lenses for the cargo light are tinted like mine is or if a clear version is available.
Originally Posted by DavesLT1
well 50 times 8000=400,000
i believe all the lenses are tinted. My 95 is, my buddy's 97 is too. I think it would look like crap if you could see the board with a clear lense.
DavesLT1- All the covers are tinted that I have seen so far and that ranges from 93 all the way to 2002; However I will say that I did see one that was more clear than anyother that are normally in there.
Indy93Z28- I make applications for 93-00 Map Lights (01 to 02 are a one piece design based on GM using a different manufacturer). I also make applications for 93 to 02 F-bodies as a whole. I currently am awaiting for my distributer to obtain more of the "Xenon White" type bulbs that where being used; however I have "Pure White" bulbs currently on the way.
Originally Posted by Indy93Z28
I'm way too lazy to do all the work listed to install tho...
Here is the latest update with the RED setup. This is only 20 RED LED's with an mcd rating of 20,000 mcd's. These buggers are BRIGHT.. They also are PERFECT for brake lights...
http://www.lastofthebreed.com/Forums/redled.jpg
You would just follow the install in my write-up. Personally I think that the Cargo one is cake considering I give you everything you need to install it including the screws. The Map Lights are the ones that no one really likes to deal with.
