Metal Widebody, now with 18 by Thirteen-y goodness
#77
Re: Metal Widebody, now with 18 by Thirteen-y goodness
No, but it's been cold in the shop, and funds are down. Progress will resume in march, and I'll start raiding the parts yard and craigslist.
I was just over at the shop checking on it, and making a list of what I'll need.
Mostly hood pieces, and some interior parts, but the real money comes in over the summer when I get the motor/trans ordered. Also front rims and tires.
I have one of the nose/fascias on order from 6litereaters initial test run. He's having some issues, but he is keeping us posted.
#78
So let me get this straight you're gonna have the Harrell lt1 front and wide body rear quarters with the perfect wheels to match and a custom hood that should flow with the entire design? Send me a pm on what parts you need I'll see what's layin around. Can't speak for anybody else but I'm excited to see this build
#79
Yep- Catfish mouth, LT1 headlights, Fiberglass front fenders, Steel rear quarters, modified hood with stretched and slanted vents, and a GM perf bare block milled out to a 400 with a 350 crank. (Almost an LS3, but not quite...) LS3 heads, LS engine management, T56.
PM coming..
#83
There' been some- I got my nose piece from 6literEater, the rears are done except for the inner fender wells, the hood is a tedious work in progress, but the shop had to get a new roof this summer, so life took precedence over parts.
I have some recent pics which I'll post later.
#84
I took some pics when I had it out in the daylight last week as the shop got a new roof. It was letting in more water than it kept out.
Getting ready to roll it out.
Big 'ol tires. Me likey.
#86
A tig welder is what you want to use on sheet metal fabrication. I have been in sheet metal fabrication for almost 16 years the one thing I know is my way around a sheet metal shop.
bending ,punching , welding, blue print reading .
that's some nice looking work on the hood !!! and rear quarter panels !! makes me wish that I put
my money in my convertible camaro instead of buying another camaro. keep up the work looking good !! I would love to see this car when you get finished
#87
Thanks! I love TIG welding, but shop is only wired for 110, and most 110 TIG's aren't worth a damn. I've gotten pretty good at stitch welding with a MIG, and using softer wire and keeping the temps down keeps the welds pliable. Most of my welds hold up to a bend test, no problem.
The hood? Urgh. It has to be dead-solid perfect. Even an 1/8th of an inch variation shows up to the naked eye because of the center line on the T-Tops. When you fab pieces without a pullmax or a brake, there's going to be some differences, and once your start tacking it in place, things really start to move, due to heat cycles- and there's where you see every little flaw.
#88
Im about 80% sure I'm gonna go ahead and do this too I keep lookin at it and the more I look at it the more I want it. I cant even imagine my car without it now...You've inspired me
stockssn2o
05-25-2015 08:54 AM
Fbodfather
25
06-21-2002 04:12 PM
