LT1 HID H4 & H3 6000k daytime pics :)
Old Oct 6, 2006 | 02:29 AM
96SilverRam's Avatar
Okay guys/gals, here are a couple of daytime pics of the HID H4 6000k low beam and H3 6000k foglights. I will try to take some pics of the lights at night once I have them adjusted. I used the optilux (hella) foglights with the blue angel eye, modified the stock foglight bracket and had it black gloss powdercoated. Everything looks as if it were OEM. Sorry, I still don't have the nose back on the car. The HID project has taken me awhile to engineer it to look and work like factory.
The HID lighting is insanely bright. Its like I was driving with no lights on with the factory lighting :lolsign:
Old Oct 6, 2006 | 08:56 AM
3800rs's Avatar
Re: LT1 HID H4 & H3 6000k daytime pics :)
looks really good.
Old Oct 6, 2006 | 11:05 AM
MarcR94v6's Avatar
Overly bright headlights behind you are a major eyesoar, I've had a set hinder my driving once.
Old Oct 6, 2006 | 11:37 AM
MarcR94v6,
You know what I'm thinking, right....
Old Oct 6, 2006 | 01:16 PM
Brangeta's Avatar
I hate bright headlights, I always turn on my high beams and blind people who have them on purpose... but at least you installed them well. They look really good.
Old Oct 6, 2006 | 03:17 PM
You must have alot of LEXUS, BMW, Mercedes, etc. really upset with you
Old Oct 6, 2006 | 07:28 PM
BlackbirdWS6's Avatar
looks really nice. I'm looking forward to the night shots. Get some of the beam pattern also if you can.
-Brian
Old Oct 7, 2006 | 05:15 AM
CrazyJim's Avatar
Member
It's only the *******s and the ricers who have lights like that... you can have a bright headlight beam and still have a pattern that doesn't blind people. As long as you do a full conversion kit and not just put new bulbs in old housings...
And you know what? If you were to ever bright light ME for having better quality headlights than what GM put on 15 years ago... I'd bright light you back, cause mine are brighter
Old Oct 7, 2006 | 10:34 AM
In many instances HID's into halogen housings get a bad rap for glare, but in some instances, the housings provide a decent beam pattern for safe use. Many also forget that HID's simply are a more intense source of light and if your eye is drawn to it....well then you are going to be more affected by it. These are the reasons why I asked him to get some shots of the beam pattern at night.
Here are some shots of my setup and if his appear to be better due to the housings he purchased then I will make a switch for obvious reasons.
Farther Away -
Far Away & at an angle
Front Shot
I still have some fine tuning to do as this was just a quick alignment done in the garage after I was done.
96SilverRam - This post was not meant to hijack the thread but more so in support of what you have done and looking forward to the results.
Old Oct 7, 2006 | 12:57 PM
After driving the car last night I could definitely tell the main lights (low beam) need to be adjusted alot. Its funny how the old lights always looked like they were correctly adjusted, you could not really tell because the output was so dim. Now that I have a solid light output you can see the beam pattern is actually tilted out on both sides, obviously this is blinding the oncoming traffic. I will need to adjust the lighting asap. Does anyone have a particular method for aligning a HID setup. The method I have found on-line is basically using a flat white wall of a business with a level area. It seems you setup a pair of cross-hairs on the wall and take some basic calculations to set the low beam lighting. I'm not sure how far away the recommended distance is to correctly set the lights ? The guide suggested 25 feet from the wall (that seem to far away ?). The foglights will also need to be adjusted down, they are 4 or 5 degrees to high. Beam pattern on the foglights appear to be correct from left to right, just need to lower them a little.
I will definitely address all the adjustments on the lighting.
Old Oct 7, 2006 | 01:04 PM
Brangeta's Avatar
Yes, I believe you're right.
Old Oct 7, 2006 | 06:45 PM
LOL
BlackBirdWS6,
I will try to PM you a few tips for the shakey lights.....
Old Oct 7, 2006 | 11:44 PM
Brangeta's Avatar
Oh, I have a tip for adjusting the headlights. You should have a person sitting in the drivers seat of the car when adjusting them if you want them fine tuned. That way your adjustments will be correct.
HectorM52
Jun 23, 2016 08:42 PM
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Jan 30, 2015 11:34 PM
blac94Z
Jan 16, 2015 11:03 PM
