Largest wheel diameter that will fit?
Old Nov 16, 2002 | 12:05 PM
Lost's Avatar
Question Largest wheel diameter that will fit?
Okay, does anyone know what is the largest overall wheel diameter that will fit under the fender without modification (no beating on the fender)? I've got this pesky wheel gap I'm looking to eliminate but I can't sacrifice any ground clearance - the true duals can't be much closer to the ground - maybe .5 inches no more. So, I'd like to put some 18's on with a 40 or 45 series tire, anyone know if that'll fit? I'd also like to stiffen up the ride but I can't handle much of a drop - anyone have any suggestions on springs - ie edelbrock that won't drop the car much? Or maybe the wheels will offset the drop.. I dunno
Help.
Old Nov 16, 2002 | 02:04 PM
pu12en12g's Avatar
You can fit 18's and 40/45 series... 19's and 35/40 series...
With 20's you would most likely need 30 series
Victor Lamb
Aug 26, 2017 02:52 PM
mongoose=
Mar 22, 2015 07:22 AM
mschmidt33
Mar 15, 2015 07:20 PM
Moshbmx1
Jan 20, 2015 03:27 PM
Starz2000ss
Oct 19, 2003 09:05 PM
