Idea for lighted door handles
I thought this my be a neat idea. Use 1 or 2 blue LED's (I have a blue LED interior). Mount them under the outside door handles, so the aren't visible. Then hook them up to the interior lights so that when the door is opened or the keyless entry, the door handle cavities will be lit up.
Any ideas or suggestions?
My idea is to drill it into the door handle bracket. If you feel up into the door handle well, you can feel to bar. I am assuming I can pull the handle out and drill a couple holes from the back. Epoxy them in and then wire them up.
Originally posted by AW/whiteZ-28
someone watched cribs
but anyway.
I went ahead and did the drivers side. You were right on drilling a hole in the door. I drilled a hole just large enough for the LED in the center of the door handle bracket and through the door. Epoxyed the LED in.
Wired it to the courtesy light. Looks pretty good. I will take some pics tomorrow and try to post them.
red man put hyperwhite leds in his escalade door handles looked good but he had the leds showing
but damn you did that quick takes me forever to debate to do something or not
so where exactly did they led go
above the handle or on the side?
so where exactly did they led go above the handle or on the side?
I uploaded a couple pics.
The pics are here
The pics are here
1 reason is to make my car look that little bit different. Another is to light the handle recesses up so that you don't have to feel around for the handle in the dark. I also have a bunch of spare blue LED's from when I swapped over the interior lights.
