How's this for an LT1 transplant candidate?
Old Jun 27, 2006 | 01:02 AM
thesoundandthefury's Avatar
http://cgi.ebay.com/ebaymotors/Repli...00360894QQrdZ1
Old Jun 27, 2006 | 01:19 AM
Zack's Avatar
Re: How's this for an LT1 transplant candidate?
just what i want to drive. a fake ferarri
Old Jun 27, 2006 | 01:59 PM
Brangeta's Avatar
:Shrugs: I don't see anything wrong with having a kit car. I say go for it!
Old Jun 27, 2006 | 02:56 PM
maxxtraction's Avatar
It's pretty nice for a kit car, but did you guys notice that the shifter looks like it would send your hand through the hvac controls when banging gears? Shorten that thing, it's not f-150, it's a f355 replica!!
Old Jun 27, 2006 | 05:29 PM
Honda Hunter's Avatar
Some people arent smart enough to understand that. Had the same discution on ls1tech.
Old Jun 27, 2006 | 07:58 PM
Thing about kit cars is that most of them are either extremely cheesy looking (batmobiles), or they try to make something that looks like the real thing but it comes out looking half baked. I was just really impressed with the quality of that kit and the fact that out of all the possible engine choices out there, the guy chose an LT1.
I found a company that makes a F355 kit that's pretty authentic and well designed, and on their specifications page they state that in full street trim, the car weighs 2,850lbs. Drop an LE2'd LT1 in one of those and you'd be able to blow the doors off the real thing.
http://www.coolcustomcars.com/355prices.html
Old Jun 27, 2006 | 08:06 PM
A car like that needs a LS7. If I had to do a LT1 I'd say a nice 355 with some huge heads and a TT setup.
Old Jun 27, 2006 | 09:01 PM
Some comparisons:
Ferrari F355 Engine
Engine 90º V 8
Engine Location Mid , longitudinally mounted
Displacement 3.495 liter / 213.3 cu in
Valvetrain 5 valves / cylinder, DOHC
Fuel feed Fuel injection
Aspiration Naturally Aspirated
Gearbox 6 speed Manual
Drive Rear wheel drive
Performance figures
Power 380 bhp / 283 KW @ 8250 rpm
Torque 363 Nm / 268 ft lbs @ 6000 rpm
BHP/Liter 109 bhp / liter
Power to weight ratio 0.28 bhp / kg
Top Speed 300 km/h / 186 mph
0-60 mph Acceleration 4.7 s
LS7
Engine type cam-in-block 90-degree V-8
Block configuration cast aluminum with pressed-in cylinder sleeves and 6-bolt, forged steel main bearing caps
Bore x Stroke (mm / in) 104.8 x 101.6 /4.125 x 4.00
Displacement (L / cu in) 7.0 / 427
Crankshaft forged steel
Connecting rods forged titanium
Pistons cast aluminum
Compression ratio 11.0:1
Cylinder heads CNC-ported aluminum; 70-cc chamber volume
Valve size, intake (mm / in) 56 / 2.20 (titanium)
Valve size, exhaust (mm / in) 41 / 1.61 (sodium-filled)
Camshaft hydraulic roller; 15 mm (.591 in) lift (intake and exhaust)
Rocker arms 1.8:1; offset (intake only)
Air intake composite manifold with 90 mm single-bore throttle body
Fuel Premium required. 91 octane minimum
Horsepower 505 (373 kW) @ 6200 rpm
Torque (lb-ft) 475 (644 Nm) @ 4800 rpm
Engine redline (rpm) 7000
I knew a guy who did a SBC swap into a Fiero. It was a 383 that put out around 450lb./ft. Main problem he had was keeping the front end planted whenever he punched it. (Not that this isn't extremely cool.) It wasn't very long and he started having body mounts coming loose and the body panels themselves were spider-webbing. You have to remember, in a Z06 the weight distribution is an almost perfect 51%front/49% rear, whereas a Fiero has more like 40%front/60% rear. A huge torque monster like an LS7 in that car, while I'm sure would be a blast, would probably do alot to shorten the lifespan of the kit. I think this might be one of the few instances where a destroked motor with a peaky cam might be of more benefit. (A 302 LT1 might be kinda unique.)
I wonder how a 302 LT1 with an aftermarket EFI setup that could handle the tuning requirements for 8,000rpms and breathing through a Tubi exhaust would sound....
Old Jun 27, 2006 | 09:15 PM
Very good point. Now that i think about it most cars of this nature dont go with extreme engines. They usually go with something small that makes average power I guess because average power in a light car still screams.
Hot Rod Hawk
Aug 30, 2002 10:12 PM
91 Redd Sledd
Aug 14, 2002 02:02 AM
91 Redd Sledd
Aug 3, 2002 11:50 AM
Zone
Jul 29, 2002 07:43 PM
