How to properly clean a windshield?
Old May 24, 2014 | 06:21 PM
Laymaster's Avatar
The area the wipers wipe is always clean but the area outside that I can never get clean. How do you guys get your windshield crystal clear?
Old May 25, 2014 | 09:30 PM
mudbone's Avatar
Use newspaper instead of paper towels or cloth rags. There's more "tooth" with newsprint, and it really does a good job.
Old May 25, 2014 | 09:37 PM
Laymaster's Avatar
Re: How to properly clean a windshield?
Which product do you use to clean the glass or does it not matter much?
Old May 26, 2014 | 06:46 AM
mudbone's Avatar
I normally use Invisible Glass. That said, newsprint works wonderfully when you are simply drying a wet car after washing. All water spots are removed with a vigorous rubbing. I grab a section of the paper and use 1 sheet at a time (crushing it into a sort of ball). Change sheets as you move around the car.
Old May 31, 2014 | 10:08 AM
96 Z 28's Avatar
I've had good luck with Invisble Glass. Although lately I had to break in a NanaSkin Mitt and it suggests breaking in on Window Glass - A big Difference - Clay Bar on Glass....
They offer a Speed Prep Sponge for quite a bit cheaper that would probably work out well for glass!
Oh and I use Optimum No Rinse (Clay Lubricant Mixture) as the lube/cleanser
KYWes
Jun 14, 2022 06:52 AM
klaymon
Oct 9, 2001 03:54 PM
SSRox
Aug 5, 2001 02:33 PM
