How do you remove the vents on a Firebird?
Old Mar 7, 2003 | 10:57 AM
kgkern01's Avatar
I want to dye my vents silver, how do I remove the vents without damaging them?
Old Mar 7, 2003 | 11:54 AM
neil350's Avatar
I would like to know a well, mines are clogged up and I need to take them out and clean the drain in them.
Old Mar 7, 2003 | 12:49 PM
ShaneS's Avatar
[edit] - if you meant dash vents, keep reading this...otherwise, ignore...
If they're the same on the pre-98s as they are on the 98+, they are a pain to figure out.
Basically, there are two little tabs on the round vent, that angle out into a groove in the dash hole. You have to reach in thru the vent with a small screwdriver and pry that tab in towards the center of the vent. As I mentioned, there are two - opposite each other, just behind the 'post' on the vent adjuster.
Took me 1/2 hour to get the first one out, but then < 5 minutes to get the next one out.
Sorry I can't be more clear - it's a lot easier to see than it is to say...
good luck!
Shane
Victor Lamb
Aug 26, 2017 02:52 PM
jmadoll
May 27, 2015 07:13 PM
grabbem88
Feb 10, 2015 06:20 PM
cmdeshon
Dec 27, 2014 10:06 AM
