How do you read treadwear?
Old Jan 8, 2003 | 03:41 AM
sleeperZragtop's Avatar
I want to know how the numbers rate, for example what does 400 mean or 140 mean? I know hard and soft to some degree, is 140 soft or hard?
Old Jan 8, 2003 | 04:07 AM
TA25th's Avatar
The higher the number, the longer the tires will last. You will get more mileage out of a 400 treadwear tire than a 140 treadwear tire.
Old Jan 8, 2003 | 12:23 PM
....is it true that the lower the number the stickier it is???
thanks...
Old Jan 8, 2003 | 01:12 PM
97FormulaWS-6's Avatar
The lower the number the"softer" the rubber compound is.
Sticker is a relative term, but typically a lower number tire will have more traction than a higher number tire.
Old Jan 8, 2003 | 01:36 PM
..what does the average drag tire rate at? the reason why I'm asking is because I want the best tire for my rear which is an 18", and I don't want to spend money on a 18" drag tire. I just want a nice sticky tire for everyday use...
Old Jan 8, 2003 | 03:33 PM
Well, my Nitto DRs are rated at 100, my Nitto 555 extreme's (Fronts) are rated at 400. I've gotten about 8-10K outta the rears, and they do need replacing. The fronts are about 4K old and look brand new.
Old Jan 8, 2003 | 06:56 PM
...thanks for your help;
Mike
DirtyDaveW
Dec 1, 2016 05:37 PM
ad356
Apr 22, 2015 08:35 PM
aj2494
Mar 12, 2015 10:17 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
