how to do led lights in your car!
Old Oct 12, 2008 | 07:55 PM
djexotic08's Avatar
ok, i decided i start by changing out my stock light with leds. i done leds before but only at partys(don't ask what i do but it's better not to know).
but since this is only on my car not a glowstick or dj equipment's. i decided to go for it of the time's i did on led lights!
so let me get started of what i got from the rca and wal-mart>
two rca led 5mm 3.3v
one roll of 18 gal. wire
couple of hest shrisk tubes
so i started by getting the white led out and started looking at how much to cut the wire!! so i decided to cut it about 1/4 off the bulb!
i forgot to take a picture of how to put the wire on the bulb without using the lead gun! but here what you do. you get two wires of 2 to 3 1/2 half inch. at both ends, rub them loose til you can get the led wire threw the wire. don't puntion a hole in the rubber wiring because it won't be good. after that...
get a heat shrisk tube and just cut enought to go around the wire's like this!
Old Oct 12, 2008 | 08:00 PM
djexotic08's Avatar
and slide it over to the end of the bulb and heat it just enough to shrisk pretty tight. if you burn it. you also burn out he bulb!
test the light if it is function
now you're ready to put the led lights in your car!
now here a tricked part. what you going to replace is the bulbs you are going to run too are these!
this bulb came out off of my console of the automation shifter light. i going to start doing this before i start doing all my light in my car!
if you done stereo systems then you may came across of these.
these are good because if you don't wanna use white anymore. you can switch other colors like blue,green,yellow, and red. but i'm going to white and soon change it to green!
i pop open the cover and cut the bulb out and started to put the connectors on and clip them down!
and this is what you are going to end up after putting the connectors.
and slide it to the light hole where the factory light was at. you can super glue it or just put some kind of housing to clip it on their!
oppss!! the led lights i use burn out so you must find a 9v led or more, which might be lil bigger but won't burn out!
Old Oct 12, 2008 | 08:21 PM
lt1 beast's Avatar
Talking
They burnout because you did not use a resistor, and if you did; you did not use the correct one. Have you ever use spell check?
Old Oct 12, 2008 | 08:33 PM
djexotic08's Avatar
sorry, i had to hurry it up because i was a girl house!!!
Old Oct 12, 2008 | 08:58 PM
Angelis83LT's Avatar
I have done LED using a PCB and resistor, and get it to plug right into the stock socket.. For quick though your way does work, if you put a resistor in there so the voltage drops for the led, you would be good.
Old Oct 12, 2008 | 11:10 PM
djexotic08's Avatar
yeah, that the one thing i forgot to do. i get it done Wednesday.
Old Oct 17, 2008 | 07:13 PM
1997FormulaBird's Avatar
...and you had to get out before her BF came home?
lol im just kidding sorry
but yeah I did this with leds and a resistor. Go bright though or you can hardly see it bc of the position of the light in the fixture
Old Oct 17, 2008 | 11:06 PM
Brangeta's Avatar
Do you turn your "stick" into a "glow stick" by putting an LED in it?
Old Oct 18, 2008 | 11:30 PM
djexotic08's Avatar
no but i got tired of that low yellow light. i wanted brighter!!!
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
Eric H
Aug 10, 2002 06:39 AM
