How do I remove clear coat from a rim??
Old Mar 19, 2004 | 10:23 PM
Birdman7389's Avatar
I just bought a 71 Fomula 'bird with some american racing rims on it...the clear coat is peeling and look pretty lame.
What is the best way to remove the remaining clear coat??
Old Mar 20, 2004 | 12:20 PM
Black_Z28's Avatar
Get some sandpaper. That's your best bet. I'd start off with a 500-250 grit. And go from there.
Old Mar 20, 2004 | 12:26 PM
Knowklew's Avatar
why dont you just bring them to a shop and have them redone
Old Mar 20, 2004 | 01:35 PM
They are chrome and in great shape, except for the clear coat peeling. Most places its allmost all the way off, I tried getting it off with a razor blade and it worked ok....time consuming but ok.
Old Mar 22, 2004 | 08:00 AM
germ79's Avatar
I just stripped the clearcoat off of my polished aluminum wheels over the winter. I used Aircraft Paint Stripper. You can get it at about any hardware store and some auto places like Autozone. It works great!
Jeremy
Old Mar 22, 2004 | 01:30 PM
94BlackBowtie's Avatar
Jeremy
That's what you need.
Sandpaper will scratch the surface below the clear coat...wouldn't risk that.
Just pick up a can or two of this stuff from Wal-Mart, in the automotive section. It is in a blue and white can and its called "Aircraft Remover" made by Kleen-Strip I believe. I have used it several times - works great. Just spray it on - the about 15 minutes later - wipe it off or scrape it off with a plastic scraper. Shouldn't hurt the finish underneath - as long as it isn't painted.
Old Mar 23, 2004 | 05:53 AM
sweet, I'll give that a shot!
R@mpage
Apr 20, 2015 10:02 AM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
ModdedNerd
Jan 29, 2015 07:23 PM
