How do I get my dash apart to disable my DRL
you take a a-pillars off (if you never done it before take both off) by unscrewing 2 philipses under the t-tops they carefuly pop up the top side of the dash. take your time because it can easyly crack or brake in two pices. it holds by a few pins and the havy duty velcro. Will probably take you around 10-15 min for the first time then your'e on your own.
actually, you don't even need to take the a pillars off. When you look at the dash, the sensor is right by the factory led light for the alarm. Just pull up on that and you'll be able to get to the sensor. I've done this mod to many cars and never had to take the a pillars of the car. Just pull up on the dash it self but just enough so you can get under there.
