How do I get my dash apart to disable my DRL
Old Nov 5, 2003 | 09:41 PM
My 97 Z28's Avatar
How do I get my dash apart to disable my DRL's?
Old Nov 6, 2003 | 08:30 AM
catsnet's Avatar
you take a a-pillars off (if you never done it before take both off) by unscrewing 2 philipses under the t-tops they carefuly pop up the top side of the dash. take your time because it can easyly crack or brake in two pices. it holds by a few pins and the havy duty velcro. Will probably take you around 10-15 min for the first time then your'e on your own.
Old Nov 6, 2003 | 11:42 AM
AW/whiteZ-28's Avatar
Be VERY careful taking of that dash pad alot of people break them. Don't lift it too high just enough to get your hand underneath to loosen the entire thing the pull it out.
Old Nov 6, 2003 | 09:31 PM
PaulN64's Avatar
actually, you don't even need to take the a pillars off. When you look at the dash, the sensor is right by the factory led light for the alarm. Just pull up on that and you'll be able to get to the sensor. I've done this mod to many cars and never had to take the a pillars of the car. Just pull up on the dash it self but just enough so you can get under there.
David Dempsey
Mar 12, 2016 12:42 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Greg88
Sep 20, 2015 07:14 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Daluchman1974
Sep 11, 2015 06:12 AM
