help with ss dash plaque
Old Nov 21, 2003 | 02:03 PM
Buffdaddy's Avatar
Unhappy help with ss dash plaque
I am trying to replace the camaro letters above the clock with the camaro ss dash plaque, and can not get it. I tried using a blow dryer for about 20 minutes and nothing happened. What do I do? Thanks for your help.
Old Nov 21, 2003 | 02:12 PM
AW/whiteZ-28's Avatar
If you are talking about the 97-02 interior with the name plate by the fog light switch and asr switch that is not a sticker. it pops out its a plastic piece
Old Nov 21, 2003 | 04:35 PM
Buffdaddy's Avatar
Then how do I replace the camaro letters if it is plastic. The dash plaque is supposed to fit right on that spot.
Old Nov 21, 2003 | 08:26 PM
JasonD's Avatar
Admin Emeritus
If it is what I am thinking it is, you have to pop the entire trim ring off. This is the big plastic piece that surrounds the heating controls, radio and contains the center vents. It just pops right off. Be careful not to break it.
The Camaro plaque is not glued on like the SS plaque, it "snaps" into the trim ring. After you pop the ring off, look at the back side and you will see what I mean.
David Dempsey
Mar 12, 2016 12:42 AM
Greg88
Sep 20, 2015 07:14 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
