Help me out here guys...'97+ T/L on '96-
Old Sep 30, 2002 | 09:56 AM
94BlackBowtie's Avatar
I searched for every term I could think of, because I know that this has been posted, but where's the instructions on how to swap out the pre '97 tail lights out with the newer ones? I don't have the new wiring harness or anything either...is it possible to do without the new wiring harness? All help would be appreciated. If you know of a thread on here that tells about it, just point me in that direction...
Thanks!
Edit: This is on a '94, I think '96's may actually have different wiring???
Old Sep 30, 2002 | 11:37 AM
StreamlineZ28's Avatar
just a question but why do you want the new ones
i like ours better they have no orange on them
just my opinion though
Old Sep 30, 2002 | 11:40 AM
Well, just as you like the all red ones better, I like the newer ones better...
Old Sep 30, 2002 | 01:07 PM
MILESF's Avatar
Talking
Try this: http://dz28.150m.com/
Daniel did a fantastic job on this subject!
Hope this helps.
Fred
Old Sep 30, 2002 | 01:25 PM
Thanks for the link, and yes he did do an excellent job! But he says you must have the newer wiring harness...Is this the case? I can use his instructions for everything else I think, but I just need to know if I must have the newer harness. I thought there was some kind of adapter or some kind of bypass you could make on it or something...?
Old Sep 30, 2002 | 02:21 PM
MILESF's Avatar
Talking
If you do have a 94, you will need the newer harness. I had to do the same thing when I did my export lights.
Fred
Old Sep 30, 2002 | 02:26 PM
Fred, thanks for your help...since I indeed must have the newer harness, do you know where I can find one reasonably priced? I have some contacts I am going to check with, and I'll check out the F/S section here, but if you know of somewhere as well, it won't hurt anything to check everywhere I can...
Thanks again...
DLB
Edit: I can get one locally for $25, that's probably the route I'll take...
Old Sep 30, 2002 | 03:58 PM
DansZs's Avatar
You might try contacting Tim using the exportstyle email address on the website. I know he used his stock harness for his export taillights, but it was a big pain! He said he had to cut the bulb sockets out and rewire them. Just like Fred says, get the 97+ wire harness b/c it'll make life much easier!
BTW Fred, I wasn't sure if you read my earlier post and I wanted to let you know that your interior look great!
Old Sep 30, 2002 | 04:09 PM
Thanks guys...
I am just gonna get the $25 harness...I am getting a good deal on the lights, so I can afford to do it right...Plus I don't like to halfway do something...Thanks again.
Old Sep 30, 2002 | 04:17 PM
Eric H's Avatar
I put '97+ lights on my '95 using the stock harness. It was quite a while ago, but all I can say is that it took me forever to figure out how to do it. I seem to remember rewiring a lot of it...
-Eric H
Dark Angel
Jun 28, 2020 04:55 AM
maybe2fast
Feb 27, 2015 08:09 AM
94BlackBowtie
Jun 7, 2004 10:28 AM
ExMustangOwner
Nov 20, 2002 12:22 PM
pewter99SS
Oct 30, 2002 05:02 PM
