Help me out here guys...'97+ T/L on '96-
I searched for every term I could think of, because I know that this has been posted, but where's the instructions on how to swap out the pre '97 tail lights out with the newer ones? I don't have the new wiring harness or anything either...is it possible to do without the new wiring harness? All help would be appreciated. If you know of a thread on here that tells about it, just point me in that direction...
Thanks!
Edit: This is on a '94, I think '96's may actually have different wiring???
Thanks!
Originally posted by StreamlineZ28
just a question but why do you want the new ones
i like ours better they have no orange on them
just my opinion though
Thanks for the link, and yes he did do an excellent job! But he says you must have the newer wiring harness...Is this the case? I can use his instructions for everything else I think, but I just need to know if I must have the newer harness. I thought there was some kind of adapter or some kind of bypass you could make on it or something...?
Originally posted by MILESF
If you do have a 94, you will need the newer harness.
Thanks again...
DLB
Edit: I can get one locally for $25, that's probably the route I'll take...
You might try contacting Tim using the exportstyle email address on the website. I know he used his stock harness for his export taillights, but it was a big pain! He said he had to cut the bulb sockets out and rewire them. Just like Fred says, get the 97+ wire harness b/c it'll make life much easier!
BTW Fred, I wasn't sure if you read my earlier post and I wanted to let you know that your interior look great!
Thanks guys...
I am just gonna get the $25 harness...I am getting a good deal on the lights, so I can afford to do it right...Plus I don't like to halfway do something...Thanks again.
I put '97+ lights on my '95 using the stock harness. It was quite a while ago, but all I can say is that it took me forever to figure out how to do it. I seem to remember rewiring a lot of it...
-Eric H
-Eric H
94BlackBowtie
Jun 7, 2004 10:28 AM
ExMustangOwner
Nov 20, 2002 12:22 PM
