Help with ff75 isntall
Ok, i got it all installed and stuff with the hella harness, now, from the relay, it has a green wire on the relay it is connected to circuit 86, where does the other end of it go? I have 2, one for high beams, one for low beams.
These are supposed to go into the stock harness so either low beams or high beams turn on, one for each, right? where do I splice them into? Pics appreciated.
Ok, hooked them up but for some reason...
the inside lamps, turn on on low beams, then when high beams, the outsides turn on, and all 4 are shows. humn.
but omg, the ff75's make the car look soo much better, will have a few pics soon, waiting for dark to regulate and take pics of lit.
CheshireCat
Oct 12, 2007 04:46 PM
