Help with 93 led tail lights?
Old Sep 23, 2008 | 03:04 PM
lt1z28camaroguy's Avatar
I recently bought Altezza LED Tail lights for my 93 camaro and when I tried to install them the tail lights wouldn't plug in and i was just wondering what im doing wrong or if i need an adapter or something?
Old Dec 8, 2008 | 01:44 AM
ChevyLT1Camaro94's Avatar
post pictures of what you have going on and i may be able to help, ineed to see the sockets on your car, and the sockets on the led tail lights.
Old Sep 23, 2010 | 02:57 PM
ecko1226's Avatar
I have the same problem
Old Sep 23, 2010 | 02:58 PM
ecko1226's Avatar
if u found out what to do plz tell me
Old Sep 23, 2010 | 03:13 PM
94 Camaro Z28's Avatar
Is this serious?
Old Sep 23, 2010 | 03:17 PM
MeenZ28's Avatar
The LED tails on Ebay are made for the 98+ tails. They use differant sockets. You're either going to have to switch out the harness or hardwire in all new sockets for this to work.
Old Sep 23, 2010 | 03:18 PM
ecko1226's Avatar
yea it is...
Old Sep 23, 2010 | 03:22 PM
Well its obvious that your stock socket is made to hold a bulb, not a plug in for a tail light assembly. I mean you pulled a bulb out of the socket to start with right?
You're going to have to take the socket out, then hook up the wires to your new plug in. You might need to have a test light so you know which wires go where, IE brake light, turn signal, etc.
Old Sep 23, 2010 | 05:19 PM
Brangeta's Avatar
^^GM's method of preventing ugly Euro tail lamps from being installed?
Old Sep 23, 2010 | 05:38 PM
Procharged94Lt1's Avatar
Ah yes...the joys of Ebay and their glorious listings saying their parts will fit just about anything.
Try and find a part-out car and see about wiring in the harness from a 98+ Z and you should be a lot better off. No matter what you do though you will be cutting wires to make them work.
Old Sep 23, 2010 | 08:22 PM
GreenDemon's Avatar
Talk to these guys:
http://www.tacreationsusa.com/
Considering that everyone wants the taillights and not the harness/sockets, you can probably get them pretty cheap.
Parts stores might have them too, 3057 bulbs are very common in later model gm vehicles.
Old Sep 24, 2010 | 02:55 AM
ecko1226's Avatar
thx u all....i just got it to work by directly wiring it together
Klypto
Parts Wanted
Apr 22, 2015 07:08 AM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
Jlo
Feb 3, 2015 09:41 PM
CaRParts102
Dec 6, 2014 08:45 AM
JoFerZ
Aug 31, 2003 12:49 AM
