Help with 93 led tail lights?
I recently bought Altezza LED Tail lights for my 93 camaro and when I tried to install them the tail lights wouldn't plug in and i was just wondering what im doing wrong or if i need an adapter or something?
Well its obvious that your stock socket is made to hold a bulb, not a plug in for a tail light assembly. I mean you pulled a bulb out of the socket to start with right?
You're going to have to take the socket out, then hook up the wires to your new plug in. You might need to have a test light so you know which wires go where, IE brake light, turn signal, etc.
Ah yes...the joys of Ebay and their glorious listings saying their parts will fit just about anything.
Try and find a part-out car and see about wiring in the harness from a 98+ Z and you should be a lot better off. No matter what you do though you will be cutting wires to make them work.
Talk to these guys:
http://www.tacreationsusa.com/
Considering that everyone wants the taillights and not the harness/sockets, you can probably get them pretty cheap.
Parts stores might have them too, 3057 bulbs are very common in later model gm vehicles.
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
