Headlights out!! Help quick
Old Nov 19, 2003 | 04:09 PM
Snoman73's Avatar
both my low beams decided to go out within 3 days of each other, i have a 95 camaro with stock headlight setup, ive never changed the headlight bulbs since ive had it, so what low beam bulbs do i need? and how to i put em in? thanks guys
Old Nov 19, 2003 | 04:22 PM
AW/whiteZ-28's Avatar
You have to buy the entire housing go to the auto parts store and pick up 2 of this part number H4351 and you are going to need a small torx driver take out the 4 torx screws around the headlight bezel andpull the entire thing out replace it and put the screws back in
Old Nov 20, 2003 | 07:47 AM
94BlackBowtie's Avatar
If you want to go the cheap way out and keep it stock just pick up a couple of regular Sylvania 9006 Bulbs and do the old bulb swap trick. Link Here. That will save you about $35.
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Greg88
Sep 20, 2015 07:14 PM
NewsBot
Sep 14, 2015 09:20 AM
jackpawt883
Sep 10, 2015 08:53 PM
