Head unit Delete Plate?
Old Mar 10, 2008 | 06:14 AM
METALBEAST's Avatar
I removed my old head unit from my 97 Z for weight reduction purposes. Is there a !head unit plate available for this? Thanks.
Old Mar 10, 2008 | 07:23 AM
blackbirdta's Avatar
you removed a head unit for weight reduction putting a delete plate in would add weight...
Old Mar 10, 2008 | 07:45 AM
2000GTP's Avatar
A plate won't add that much weight. Maybe look up Injuneer, he did the radio delete and fabbed up a blank faceplate. It turned out really good.
Old Mar 10, 2008 | 08:31 AM
shock6906's Avatar
Better take out the speakers too...
At any rate, a thin sheet of aluminum trimmed to size would do the trick. You can also go to Lowes and get a sheet of 1/8" acrylic that will only cost you a couple of dollars. Then, if you really want to make it look nice, you can get "Camaro Z-28" in vinyl letters (in reverse, of course) and make a mask. Scuff the rear side of the acrylic plate, apply the mask to the center, paint it black, remove the mask, and then you can backlight it for a really cool look. Of course, the couple of ounces of LED's or mini neon light might be a little too heavy for ya.
Oh yeah, to attach the acrylic plate, use some glue or something.
Old Mar 10, 2008 | 12:45 PM
I made these from thin-gauge aluminum..... weighs a few ounces, at most. The paint does add a bit too.....
My Formula....
http://www.injuneer.com/images/photo.../DCP03460a.jpg
A friends' 30th SS convertible (excuse the disorder.... it was still "under construction") I did not make the switch plate...
http://www.injuneer.com/images/photo.../DCP03866a.jpg
Old Mar 10, 2008 | 01:31 PM
i was actually just being a jackass
Old Mar 11, 2008 | 01:41 PM
METALBEAST's Avatar
My Formula....
Very nice. Probably do something like that. Did you mount it to the existing bracket?
Yes speakers are nixed.
Old Mar 12, 2008 | 03:11 PM
My Formula has the plate screwed into the stock bolt holes that would hold the head unit in place. Unfortunately, they are not all in the same plane, so I had to add shims of various thickness behind each of the holes to make it sits flush with the bezel.
On the SS, there is nothing behind the dash to bolt anything to, so they were glued in place with some RTV (hidden of course).
Old Mar 13, 2008 | 06:15 AM
METALBEAST's Avatar
Thanks as always for the info.
Old Mar 15, 2008 | 12:22 AM
bluz28's Avatar
Here you go !
http://www.moderndaymuscle.com/interior3?start=40
Old Mar 15, 2008 | 02:04 AM
Z95m6's Avatar
you can buy ABS plastic sheets for like $3 on cardomain from vendors. They come in black and have that same grain that most car interiors have in the plastic. Just get a sheet of that and glue it into your radio bezel and you're done.
Rod Bender
Jan 1, 2015 03:18 PM
JordonMusser
Sep 11, 2002 12:12 AM
screaminss
Sep 4, 2002 12:48 PM
Z28STYLE23
Aug 17, 2002 07:40 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
