hazed headlight fix
Old Dec 19, 2008 | 06:18 PM
billymz28's Avatar
hazed headlight fix
i had the worst case on my car when i bought it. We got this new 3m headlight restore at work and wow it saved me 200 bucks. It is about 20 bucks at oriellys. part # 39008 also painted the inside of the lights.
before
http://i350.photobucket.com/albums/q...8/PICT0032.jpg
after.
http://i350.photobucket.com/albums/q...8/PICT0010.jpg
Old Dec 19, 2008 | 07:11 PM
johnny6's Avatar
This should be in the appearance section.
They turned out pretty good, i'm surprised to see that no haze got on the inside of the lenses.
Old Dec 20, 2008 | 06:40 AM
AL SS590 M6's Avatar
Moderator
And that's where t'll be.
OP please post engne questons only n ths forum.
Old Jan 4, 2009 | 07:47 AM
97QuasarBlue3.8's Avatar
The haze is caused by UV damage as well as atomspheric particulates that settle on the plastic. It's not usually an "inside the lens" phenomenon.
If you have a decent buffer and some compound, you can wet-sand and polish the plastic to like-new appearance. The 3M compound seems to have worked pretty well, although there's still a little yellow tinge left behind. Maybe another pass with the cleaner?
Old Jan 4, 2009 | 09:52 PM
Counted Out's Avatar
I just wet-sanded mine, starting with 800grit and working up to 2,000grit, then used a plastic polish to shine them up. They came out looking damn perfect.
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
Aug 17, 2015 09:50 AM
FredM
Aug 14, 2015 01:49 PM
Henson071
Aug 4, 2015 09:32 AM
