GREAT upgrade for those crappy headlights!! (photos w/ in)
Old Aug 17, 2005 | 07:59 AM
  #241
skisax80's Avatar
Re: GREAT upgrade for those crappy headlights!! (photos w/ in)
gotta keep this alive... so i can make sure to have it for later when i get time and money to do this...
Old Aug 17, 2005 | 07:49 PM
  #242
PediDr2's Avatar
I've had my setup on for about three years. I had some trouble with the initial install and broke one of the plastic 'pop in adjuster' thingies. I got it to work with a generic HELP style headlight adjuster. Now three years later another 'pop in adjuster' thingie fractured. I was able to make do with a piece of conduit fastener so at least I can adjust the light properly now.
Wonder if anyone has a better system of installing these?
Once they are in and secure (even 2 of the 3 adjusters ) it's not the easiest to remove and redo.
Old Aug 17, 2005 | 10:33 PM
  #243
Sam95ZNoTop's Avatar
I fastened my HID retrofitted 90mm modules with 3 standard 1/4-20 bolts and a bunch of washers and nuts. I get the adjustment close tightening by hand, then I tighten the nuts a little and fine adjust using the phillips head on the bolt. Once it's all where I want it, I tighten the nuts holding the bolt with a phillips head screwdriver.
I have had the lights out again after installation, leaving the bolts and all but the very back nuts on the light and I was able to put them back in without barely having to adjust them. Works much better than the adjusters that come with the lights.
HTH
Sam
Old Aug 17, 2005 | 10:52 PM
  #244
PediDr2's Avatar
Do you have pics of the adjusters you used?
Has anyone used the 'Mounting Plate'?
http://www.rallylights.com/hella/hel...es/SMS90MP.jpg
Old Aug 18, 2005 | 09:24 PM
  #245
I don't have pics, but I could take some.... maybe this weekend I'll get to that... I have not used the mounting plates, nor do I know someone who has, I doubt they would work for our cars though.
Sam
Old Aug 19, 2005 | 09:48 AM
  #246
Bud M's Avatar
I used the mounting plates. IMIO its the only way to go.
http://pg.photos.yahoo.com/ph/buds93...3a.jpg&.src=ph
http://pg.photos.yahoo.com/ph/buds93...c2.jpg&.src=ph
http://pg.photos.yahoo.com/ph/buds93...a3.jpg&.src=ph
Old Aug 21, 2005 | 10:03 PM
  #247
PediDr2's Avatar
Looks nice. Way too pricey for me.
Any chance anyone could scan the design for those brackets? I know a machinist who owes me
Old Oct 25, 2005 | 10:26 AM
  #248
Gripenfelter's Avatar
Anyone using these?
http://www.rallylights.com/hella/ff075.asp
Are they easier to mount than the Hella 90mm?
Can you run HIDs in the FF75s? What HID bulbs would you need?
Can you run FF75s as fog lights?
Old Oct 26, 2005 | 08:05 PM
  #249
Loony's Avatar
To the original poster, or anyone else that knows I guess...how does the size of these lights compare to the Rytek kit? Thanks!
Old Oct 27, 2005 | 07:18 PM
  #250
PediDr2's Avatar
Similar/Same. There's a good writeup on the Rytek or PIAA equivalent on Brent Franker's site.
http://www.bfranker.badz28.com/94Z/piaa.htm
Old Oct 27, 2005 | 09:31 PM
  #251
Originally Posted by Gripenfelter
Anyone using these?
I have a set (driving light version) that I put 100W H7 bulbs in as a replacement for the stock fogs. And I have figured out a way for them to come on ONLY with the highs. I already have plenty of low beam light
I guess you could put a H7 HID kit in them, but these lights are really only good as high beam/driving lights. And the constant switching on and off you usually do with high beams will wear out the HID bulbs and ballasts pretty quick, not to mention your wiring (16A / lamp on startup). Using these lights as low beams is downright dangerous, since they do not have a cutoff. Putting a HID kit in them is going to make the glare even more than it already is stock, so I would highly discourage that.
JMHO,
Sam
Old Oct 30, 2005 | 03:37 PM
  #252
NOVA5's Avatar
what i find interesting is the difference in brightness between viewing through the windsheild and sticking your head out the window looking forward. better visibility without the windshield in the way.
Old Nov 2, 2005 | 02:14 PM
  #253
CHELOZ28's Avatar
where would I purchase these lights? Also will they come with the mounting bracket, sorry If someone has posted this exact same question, I was too lazy to read through the whole 17 pages
Old Nov 2, 2005 | 08:59 PM
  #254
Check on the link in my sig, it has all the info on my webpage.
HTH
Sam
Old Dec 12, 2005 | 11:11 AM
  #255
94BlackBowtie's Avatar
Over a month and no replies! Goodness people!
