Gauges..?
Old Aug 12, 2004 | 08:29 PM
LetMeBurnU's Avatar
Gauges..?
Im looking into the dual gauge pod, i was thinking of triple but decided to go for dual. Anyways im deciding on which gauges to get. I know i dont need BOOST cause i wont be putting on a blower or nx. Im thinking of the vacuum gauge and water temp gauge. Any inputs?
Old Aug 13, 2004 | 07:20 AM
BigEvil's Avatar
Re: Gauges..?
Air/Fuel
Tranny temp
Old Aug 13, 2004 | 07:31 AM
Re: Gauges..?
I run:
-fuel pressure
-nitrous pressure
-oil pressure
-trans temperature
-engine oil temperature
Old Aug 13, 2004 | 09:32 AM
SplitFire's Avatar
Re: Gauges..?
I put an oil pressure gauge on because I was having problems with my stock gauge. I also but a transmission temp gauge in.
Old Aug 13, 2004 | 01:28 PM
Somnambulist's Avatar
Re: Gauges..?
im gonna have:
-A/F
-trans temp
-oil pressure
if yo uhave an elec. WP, get the water temp gauge...
Old Aug 13, 2004 | 02:54 PM
Will84's Avatar
Re: Gauges..?
The A/F is fine to have... If you want the look, but they're not accurate enough for tuning unless you have wideband. It will tell you lean or rich... but not exact numbers... which is what you want.
Someone correct me on this if I'm wrong.
Old Aug 13, 2004 | 06:23 PM
Re: Gauges..?
no youre right..the O2's are pretty innacurate on our cars so the A/F would just be used as a 'general knowledge' of sorts...
Old Aug 13, 2004 | 08:34 PM
dabez1's Avatar
Re: Gauges..?
how bout a clock like the ones in walmart????
Old Aug 13, 2004 | 09:32 PM
catsnet's Avatar
Re: Gauges..?
I have 2 in the a-pillarr and 2 in the CD holder place
1. Fuel Pressure
2. Oil Pressure
3. Vacume
4. A/F
the air/fuel gets really annoing when it's infront of your eyes all the time though
Old Aug 13, 2004 | 11:47 PM
LetMeBurnU's Avatar
Re: Gauges..?
Is a the vacuum gauge pretty accurate.....?
Old Aug 14, 2004 | 10:36 PM
95_LT1_6SPD's Avatar
Re: Gauges..?
not much point for a trans temp in a m6.
Old Aug 14, 2004 | 11:43 PM
firebirdjosh's Avatar
Re: Gauges..?
I think getting the stock oil pressure guage repaired rather than getting another would be better. I don't know if thats the reason for replacement or if its not accurate enough. I see alot of people with ammeters, but that seems sort of pointless. A/F and Fuel Pressure sounds good.
Old Aug 15, 2004 | 04:57 PM
Re: Gauges..?
care to explain why not?
Old Aug 15, 2004 | 08:14 PM
trax's Avatar
Re: Gauges..?
Trans temp on an M6 is useful for the corner-carving guys... from my [limited] understanding the constant shifting and high revving can push your temps into unsafe levels.
Meen95z
Jul 21, 2009 06:06 PM
lt1junkie
Mar 20, 2008 08:13 AM
dist0rtion_69
Aug 8, 2007 03:08 AM
woodywagon
Feb 3, 2007 07:23 AM
dist0rtion_69
Jan 24, 2007 11:25 AM
