Gauge sweep on C5 and Cadillacs, can F-bod do this?
Old Jun 17, 2006 | 01:20 AM
  #91
stone4779's Avatar
Re: Gauge sweep on C5 and Cadillacs, can F-bod do this?
I know that if you disconnect the battery and plug it back in, any LS1 should do what the video showed above...
Just use a relay or something to disconnect the power for a sec.
But your PCM will reset, and you will lose all LTFTs etc in the PCM, as well as any tripometer data.
Now MAYBE its not controlled by the PCM, and IS controlled by the cluster, which would mean you could potentially disconnect the power for a sec from the whole cluster when the ACC ON wire is hot, then it send back to normal operation. (Maybe using a relay?)
If this is true then you could keep your LTFTs etc in the PCM, but still not the tripometer, which Im pretty sure is stored in a chip in the cluster, like the mileage.
Any more work than that and it just isnt worth it...to me anyways.
Formula Steve
Sep 19, 2023 08:31 AM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
themex2002
Sep 2, 2015 03:47 PM
