Gauge Problem
I put in my new white face gauges and now my needles are all mest up there starting in the wrong places when you turn the key. There also slow moving up and hesitating then the'll move and hesitate again same way going down. What can I do to fix this?
Also I have the gauges that change from blue to green I have to splice them into the parking lights and im not sure which wire is the power and the ground is there a diagram or does anyone know?
Thanks in advance.
Also I have the gauges that change from blue to green I have to splice them into the parking lights and im not sure which wire is the power and the ground is there a diagram or does anyone know? Thanks in advance.
Your overlay is bubling up and touching the needles causing them to stick. You will need to use some two sided tape to prevent this. If the overlay touches the needle even just a little it will stick.
99TransAmWS6
Feb 12, 2015 07:23 PM
slothgrant
Aug 22, 2002 03:01 PM
