Gauge Problem
Old Sep 27, 2003 | 03:30 PM
Maro98's Avatar
Angry White Face Gauges
I put in my new white face gauges and now my needles are all mest up there starting in the wrong places when you turn the key. There also slow moving up and hesitating then the'll move and hesitate again same way going down. What can I do to fix this? Also I have the gauges that change from blue to green I have to splice them into the parking lights and im not sure which wire is the power and the ground is there a diagram or does anyone know?
Thanks in advance.
Old Sep 27, 2003 | 07:04 PM
VegasZ's Avatar
Your overlay is bubling up and touching the needles causing them to stick. You will need to use some two sided tape to prevent this. If the overlay touches the needle even just a little it will stick.
Old Sep 27, 2003 | 08:39 PM
Maro98's Avatar
I Thought about doing that wont i be able to see the tape through the Gauges at night when it is lit up?
warmeck
Mar 22, 2015 06:43 PM
mattstrike
Mar 11, 2015 07:33 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
blac94Z
Nov 24, 2014 07:12 PM
slothgrant
Aug 22, 2002 03:01 PM
