gauge for drag airbag in rear spring
Old Jan 19, 2006 | 09:32 PM
luckyou03's Avatar
I thought about mounting a gauge on my center console to monitor the psi rating of the air bag in my rear spring. I could let all the air out for cruising and fill it back up when I need to. What do you guys think about this?
I also thought about getting a small 5"x5" aluminum tank, polishing it and mounting it where my rear seat used to be so I could store like 200lbs in it. I would be able to fill and drain the bag a few times without stopping.
Old Jan 19, 2006 | 09:51 PM
luckyou03's Avatar
Re: gauge for drag airbag in rear spring
something like this:
Old Jan 19, 2006 | 11:45 PM
AirLift sells a small compressor, switch and pressure gauge in a kit.
Load Controller II
Available in Single and Dual Gauge Kits
(Single Gauge Kit Shown Above)
Each Load Controller II kit is complete with a 12-volt compressor, gauge dash panel with inflate and deflate controls, all electrical connections, air lines, fittings, low pressure sensor, and a detailed, illustrated installation manual.
(Kit contents vary by application.)
Single Gauge Kit Recommended for all passenger cars, SUVs, mini vans, and most pickup truck applications when the load is centered and only occasional use is required.
• Single gauge for even filling and exhausting of both air bags.
• Air adjustability right from the dash of your vehicle, up to 100 p.s.i. for maximum roll stability.
• One year limited warranty.
Moshbmx1
Jan 20, 2015 03:27 PM
ModdedNerd
Dec 25, 2014 05:51 PM
wytblur
Mar 2, 2003 03:40 PM
