Flex Additive (paint guys here)
Old May 1, 2003 | 03:42 PM
Robert95z's Avatar
Im painting my front bumper, is a flex additive required on 2 stage paints? (base coat/clear coat). If so does the flex additive go into the base coat or clear coat, or both.
thanks
Old May 1, 2003 | 03:48 PM
chuckys95's Avatar
with 2 stage base coat/ clear coat paints, the flex additive only goes in the clear.
hope this helps ya!
Old May 1, 2003 | 04:46 PM
Robert95z's Avatar
Thanks chucky!
Old May 1, 2003 | 11:27 PM
Matt97PTA's Avatar
actuallu i really dont think you should even need to worry about it. Ive cleared a pice of flexible plastic before with dupount HC-7600 and i can bent it alot farther than your bumper will ever flex without cracking, but it wont reawlly hurt
Old May 1, 2003 | 11:49 PM
Robert95z's Avatar
I'll be using ChromaClear 4500S, i'll probably throw in the flex additive unless i actually do not need it.
On a side note, is there anywhere online to buy dupont paint products?
Old May 2, 2003 | 12:33 PM
Bralgar's Avatar
Thumbs up
Definately add the flex to your clear, not only does it help with preventing cracks it also prevents bug and rock chips, since the clear will be 'springier'. Chips and cracks occur because of the hardness of the clear not wanting to give. Now I'm not saying chips will never happen with flex, but the likelyhood will be greatly diminished.
Richardan15
May 30, 2015 08:36 AM
Brake_L8
Jan 20, 2015 09:44 AM
Red97LT1
Aug 7, 2002 05:45 PM
