Fenders wont align
Old Mar 14, 2005 | 07:39 PM
pHEnomIC's Avatar
Fenders wont align
I hada little crack on the bottom of both of my fenders so i took them off to epoxy the backs so they wouldnt move and therefore hide the cracks. I tried hard to get the fenders to align with no luck. Can anyone give me any tips? What is the general process. I even played with the hood itself with no luck. Whats the general process to get it flush?
Old Mar 15, 2005 | 09:06 AM
Brent94Z's Avatar
Super Moderator
Re: Fenders wont align
I'm not sure of the process but know a friend of mine spent nearly all day trying to align an aftermarket hood and couldn't do it. Finally gave up and took it to a body shop and they had it done and looking perfect in less than an hour. Good luck! But, you might just end up needing to take it to a body shop
Old Mar 15, 2005 | 09:55 AM
Bone Daddy's Avatar
I just ran into this problem when I started rebuilding my front clip. Like brent says, a good alighn can take hours if not all day. The best thing to do is to line the fender up at the doorjamb first, then secure the length of it second. There are 3 bolts there, which I'm sure your aware of by now.
First, bolt the fender to the rocker panel, alighn it, and then push up on the fender and secure the mid-bolt. (It's alot easier if you remove the fender well, and turn the wheel hard left). After this is done, and the gap looks factory, fuss with the last bolt near the mirror. If there are any tweaks left to do, the it's usually on the bottom. Consider yourself lucky, you don't have to shim anything, or bugger out any holes.
Soldier on, you'll get there. Or a body shop will.
Old Mar 31, 2005 | 10:20 PM
pHEnomIC's Avatar
I got it lookin real good this time. I ended up drilling new holes or slitting the old ones and used bigger washers and ended up getting it perfect. Whoa, the difference.
Btw, i had someone help me this time to hold the stuff in place while i tightened and it seemed to work good.
Old Apr 1, 2005 | 01:01 AM
RacingTiger04's Avatar
better luck than i had with mine, spent a few hours for a number of weeks trying to get it all to line up after i got my new hood and had the front clip painted (took it off myself and took it in to em) still havent gotten it all straight but the shop wants $300 to do it 0_0
Old Apr 1, 2005 | 01:23 PM
1-bad-z28's Avatar
just takes time and patience
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Mir Hussain
Outside of United States
Aug 8, 2015 07:00 PM
Boss002
Jul 24, 2015 10:47 AM
240ssLs3
Jul 13, 2015 05:06 PM
ducttape1975
Jul 10, 2015 06:29 PM
