Fender cracked
Old Feb 18, 2005 | 06:04 PM
pHEnomIC's Avatar
Fender cracked
My front fender is cracked about 3 inches long. It hides completely when i get it back in the correct position but every few days, the sides shift and and they dont stay level. I was wondering whats the best way to glue it back to the correct position. I know that if i glue it in place... it should be fine. Will jb weld work or should i use epoxy or even something else?
Old Feb 18, 2005 | 06:17 PM
AW/whiteZ-28's Avatar
Re: Fender cracked
Yea jb weld sounds good, if not that a plastic welder. Make sure you take the fender off and let it sit awhile before you put it back on.
Old Feb 19, 2005 | 03:00 PM
Z95m6's Avatar
Re: Fender cracked
I've had good luck gluing that kind of material together using this epoxy called plastic welder. You can get it at walmart.
magman
Apr 15, 2016 03:08 AM
RUENUF
Mar 13, 2016 03:37 PM
David Dempsey
Mar 12, 2016 12:42 AM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
