Fender cracked
My front fender is cracked about 3 inches long. It hides completely when i get it back in the correct position but every few days, the sides shift and and they dont stay level. I was wondering whats the best way to glue it back to the correct position. I know that if i glue it in place... it should be fine. Will jb weld work or should i use epoxy or even something else?
Re: Fender cracked
Yea jb weld sounds good, if not that a plastic welder. Make sure you take the fender off and let it sit awhile before you put it back on.
Re: Fender cracked
I've had good luck gluing that kind of material together using this epoxy called plastic welder. You can get it at walmart.
