Engine Bay repainted! Pics inside
Old Mar 9, 2008 | 12:28 AM
  #16
blown383's Avatar
Originally Posted by 1quickTA
Reviving an old thread here but I am interested in doing this while my engine is out right now. How long did this take you? Also, after it is all said and done, what is the final verdict on the clear coat? Do you wish you would have used it? Thanks!
I still don't have time to work on my car! I'm still debating on whether or not to clear coat the engine bay. I would assume the only areas that would turn yellow over time would be near the frame rails since the header primaries are pretty close.
-B
Old Mar 9, 2008 | 12:30 AM
  #17
blown383's Avatar
How long? The prep time was the longest so its kind of hard to say and the acutal spraying went by pretty quickly. As for the clear coat... haven't installed my engine yet. I'm working 4 jobs and have ZERO time!
-B
Old Mar 9, 2008 | 05:32 AM
  #18
Sinister/Rocinrol's Avatar
Nice job, that looks mint...definately clear it...2-3 coats!
Old Mar 9, 2008 | 07:52 AM
  #19
1quickTA's Avatar
4 Jobs! Wow.... so I guess you really don't have time. The car does look great and I hope the first drive goes great!
Old Mar 9, 2008 | 05:54 PM
  #20
d2stephen's Avatar
Looks good man
Old Mar 11, 2008 | 08:09 PM
  #21
blubird's Avatar
has anyone used the clear coat spray in a can ?
Old Mar 25, 2009 | 11:06 PM
  #22
CHELOZ28's Avatar
I was wondering after you added the primer, do you have to sand it before adding the base coat?
I bought some High Temp clear from Autozone, do you guys think this will turn yellow over time. The Clear says its good for up to 500 degrees.
Old Mar 26, 2009 | 12:48 AM
  #23
blown383's Avatar
I didn't sand the primer and I let it cure for about 24 hours before spraying the paint on.
Good luck!
-B
Old Mar 30, 2009 | 02:27 PM
  #24
CHELOZ28's Avatar
Thanks for your input man.....I'm not sure how long I should let the clear coat cure before wet sanding. Also anyone have any tips as this will be my first time wet sanding.
Here are some before and after pics, and the last pic is my car...
Old Mar 30, 2009 | 03:13 PM
  #25
Brangeta's Avatar
I like the black engine bay look.
Old Mar 30, 2009 | 04:43 PM
  #26
BC2002SS's Avatar
I use a 20oz water bottle with a hole in the cap. water will drip out some what slowly and you can just squeeze it when you need more water. never let it get dry and use a water blade to dry so you can check your progress. don't over do it
rjc1629
Jan 27, 2015 10:46 AM
formula218
Dec 2, 2014 04:27 PM
omarECD
Aug 19, 2002 07:28 AM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
305fan
Jun 27, 2002 09:44 AM
