Engine Bay repainted! Pics inside
Old Oct 11, 2006 | 03:05 PM
blown383's Avatar
Finally done with repainting the engine bay and surprisingly enough the Dupli-Color rattle cans from Pep Boys matched the paint perfectly! They have a little book with OEM colors and the matching Dupli-Color can. I couldn't justify spending $75-100 on paint that will never be seen 99% of the time and that I would screw up anyways.
I have some runs in the paint due to the crappy spray pattern so it looks like I'm going to wet sand it with 1200-3000 grit and polishing it with some compound.
-B
Old Oct 11, 2006 | 03:16 PM
2000GTP's Avatar
Re: Engine Bay repainted! Pics inside
Looks very nice, I can't wait till the time rolls around for me when I get that done.
Old Oct 11, 2006 | 03:44 PM
Jun10rp's Avatar
Looks good
Old Oct 11, 2006 | 07:13 PM
Brangeta's Avatar
That's pretty close to Sebring Silver, looks good.
Old Oct 11, 2006 | 08:37 PM
Brent94Z's Avatar
Super Moderator
Damn nice for spray cans... way better than what you get from the factory
Old Oct 11, 2006 | 09:53 PM
sko_spo's Avatar
holy fack that looks nice
Old Oct 11, 2006 | 10:20 PM
johnny6's Avatar
Dupli color did that? Thats pretty nice, did you use any clear coat?
Old Oct 12, 2006 | 01:41 AM
blown383's Avatar
Thanks for the compliment guys!
I got the finish with lots of prep.
1) Removed EVERYTHING from the engine bay.
2) Sprayed down the entire engine bay with brake cleaner and scrubbed off the greasiest parts.
3) I hooked up the 2400 psi gas powered pressure washer to the hot side of water faucet and blasted the the engine bay clean.
4) Block sanded everything down with 400 grit sand paper
5) Filled in the deep scratches with spot puddy.
5) Blasted everything off with compressed air and wiped it down with paint thinner
6) Wiped down the surface with a tack cloth.
7) Masked off everything. I realized that cheap *** masking tape from the $0.99 cent store sucks nuts. I should have bought the good $4-8.00 stuff and saved time.
7) Sprayed the 3 coats down with the garage door closed... didn't have a respirator so my lungs burn a little =/
After block sanding the engine bay I noticed that there is a ton of welding splatter near the connecting joints, the shock towers are horribly uneven so there are high and low spots.
The factory paint job in the engine bay sucks nuts! It wasn't even Sebring Silver... it was more like primer grey with green sprinkles in it and it was VERY thin.
The only thing I have left to do is remove the paint runs and on the flat surfaces use 1200 grit sand paper to level the orange peel. I'm debating on whether or not to add a clear coat. It would add a deep shine to it but I'm afraid of it turning yellow due to the high heat in the engine bay.
This is what it used to look like.
-B
Old Oct 12, 2006 | 01:54 AM
USA1Camaro's Avatar
Looks good
Old Oct 12, 2006 | 03:21 AM
jfman's Avatar
Did you use a primer ?
Did you sand the sheet metal before painting ?
Old Oct 12, 2006 | 03:29 AM
blown383's Avatar
I originally stripped the paint down to the metal and applied primer. Then I realized that stripping down to the metal was a complete waste of time! So I just scuffed up the old paint with 400 grit sandpaper, cleaned off the dust and went to town with the rattle can.
-B
Old Oct 12, 2006 | 01:38 PM
KillerTA's Avatar
Does it have the same non glossy finish like the factory bay has? If I wanted to do a touch up on my strut towers, do you think that it'd match?
Old Oct 12, 2006 | 03:40 PM
transAMdriv3r's Avatar
damn, why didnt i think to do that when my engine was out... probably cause i was in a hurry to drive it.
Old Mar 8, 2008 | 02:55 PM
1quickTA's Avatar
Reviving an old thread here but I am interested in doing this while my engine is out right now. How long did this take you? Also, after it is all said and done, what is the final verdict on the clear coat? Do you wish you would have used it? Thanks!
Old Mar 8, 2008 | 09:45 PM
Pandamonkey's Avatar
Wow.......that's pretty!!
