Drowning Driver Door!!
Old Nov 22, 2002 | 06:00 PM
kopperhead34's Avatar
Angry Drowning Driver Door!!
I HAVE A '94 Z28 AND THE DRIVER DOOR HAS BEEN ACCUMULATING WATER IN IT... IT NEEDS TO BE DRAINED,, HAS ANYONE EVER DONE THIS BEFORE? I SEE A BOLT ON THE INSIDE OF THE DOOR.. IS THAT THE RIGHT ONE? HOW DO I PREVENT IT FROM HAPPENING AGAIN- WHERE CAN I BUY REPLACEMENT MOLDING? THANKS FOR ANY HELP!! ed
Old Nov 22, 2002 | 06:11 PM
ibanez6rg's Avatar
Drill a hole in that sucka!
Actually I don't know, I would just start untightening bolts
Old Nov 22, 2002 | 06:16 PM
chuckys95's Avatar
check the drain holes in the bottom of the door, they are probably plugged up with debris (leaves) maybe
Old Nov 22, 2002 | 06:19 PM
OK, THANKS,, i WASN'T AWARE THERE WAS DRAINS UNDER THERE.. I'LL CHECK NOW.. THANKS AGAIN
Old Nov 23, 2002 | 03:37 AM
chuckys95's Avatar
ed,
did you find' em, if not i could take a pic of the bottom of my door to show you where they are at.
Old Nov 23, 2002 | 12:03 PM
Hi Chuck,, yes, I looked under the door every inch and didnt see any drains it is totally smooth... there is a "petcock" looking thing (for lack of a better word), on the inside of the door that is closest to the fender... could that be where to drain out the water? Thanks for your help ed
dale3in98
Feb 14, 2015 12:18 PM
Brake_L8
Jan 20, 2015 09:44 AM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
siguy
Nov 27, 2014 10:07 AM
