Door Lock & Handle Removal
Old May 13, 2008 | 06:24 AM
METALBEAST's Avatar
I am painting my 97 Z28 and I need to remove the door locks and door handles. What is the procedure to do this? I have power locks & power windows FYI. Thanks!
Old May 13, 2008 | 06:27 AM
shock6906's Avatar
Are you talking about the outer lock and handle or the inner lock and handle on the door panel?
Old May 13, 2008 | 08:07 AM
METALBEAST's Avatar
Sorry, outer lock & outer handle.
Old May 13, 2008 | 08:12 AM
shock6906's Avatar
Hmmm, I wish I could be of more help, but that's something I haven't tried to remove before. Sorry...
Old May 13, 2008 | 12:23 PM
Brangeta's Avatar
I can't help... I thought I could, but maybe this pic will give you a clue.
Old May 13, 2008 | 01:50 PM
METALBEAST's Avatar
Well its a start. Thanks! Anyone else?
Old May 13, 2008 | 02:18 PM
shock6906's Avatar
From Shoebox's website, here's a picture of the power lock assembly inside the door. I don't know if it helps or not since you can look in your door and see the same thing.
Old May 14, 2008 | 06:13 AM
METALBEAST's Avatar
Anyone else?
Old May 14, 2008 | 01:33 PM
WhiteZ95's Avatar
Its actually pretty easy to do. the first thing you have to do is to remove the door panel to access the inside of the door.
Once you have the door panel off you can look at the back of the handle and lock and you will see two connecting rods that link them to the lock solinoid and the door release.
The ends of the rods are fastened to the handle and lock by little plastic bushings.
Once you get the rods separated from the bushings you can just push them aside to get to the bolts on the handle.
The handle itself has two bolts on the inside of the door.
The lock has a little metal retaining clip that just slides onto the back of it. Just slide it off and the cylinder will come right out.
*sorry for crappy phone pictures
Old May 14, 2008 | 01:38 PM
Brangeta's Avatar
Did you do that specifically to help this guy? Wow, your rule WhiteZ95.
Old May 14, 2008 | 01:45 PM
shock6906's Avatar
Be careful with the plastic bushings that hold those rods in place. After they reach the age that they've gotten to in our cars they get pretty brittle. I had to replace them on my mom's car when her door handle stopped opening the door.
Old May 14, 2008 | 02:11 PM
Brangeta's Avatar
Yeah, the plastic sucks. On our Z28, both door handles rattle because the bushings broke on the external side and the little tiny rod that goes in them fell out
Door handles still work, but they rattle back and forth if you jiggle them.
Old May 14, 2008 | 02:18 PM
shock6906's Avatar
I think you can replace them all for just a couple of dollars. I believe the two that I got for my mom's car were less than two bucks total, and that was from the dealer. It's well worth it.
Old May 15, 2008 | 06:13 AM
METALBEAST's Avatar
Outstanding! Thanks for all your help! Thanks to everyone that responded
Old Jul 20, 2008 | 11:30 PM
1995blackttopta's Avatar
are you saying you can fix the above mentioned jiggly handle with new bearings/pins? my drivers side door handle is making that noise and im looking online at new handles (might as well do both if im gonna do one because im sure the other one will go sooner or later although i rarely use that handle)
