color codes not in door jam
Old Sep 15, 2005 | 06:04 PM
tfs95z28's Avatar
Is there another place that they are located at? The glove box has the coding BC/CC, but then nothing after it... i want to know so that i can order an SS spoiler.
tony
Old Sep 15, 2005 | 06:12 PM
RacingTiger04's Avatar
Re: color codes not in door jam
paint code should be at the bottom of the glove box sticker ... thats where mine was *shrug*
Old Sep 15, 2005 | 06:16 PM
tfs95z28's Avatar
where tho? There are a ton of codes in the glove box. When i see that code (BC/CC), there is nothing after it to let me know the color of the car... any other insight?
Old Sep 15, 2005 | 06:19 PM
TechCam97's Avatar
I thought it was before the BC/CC... Now you got me curious, I'm gonna go look.....
EDIT - Yea, it was after it. It's all the way over to the right. Mine is U8774 which is GM's Bright Red. If you have the same red as mine, that's your code.
Old Sep 15, 2005 | 06:26 PM
bowtiez28's Avatar
the question marks is your paint code bc/cc wa u????
Old Sep 15, 2005 | 06:30 PM
bowtiez28's Avatar
its on the same line as bc/cc but more in the middle and will have a "u" in front of the four digit number.
Old Sep 16, 2005 | 07:51 AM
tfs95z28's Avatar
ok, ill have to check that... from what i remember, i didnt see any code in that line at all whatsoever. Thanks a lot guys... im pretty sure that it is probably the same code as you TechCam97... there werent a whole lot of variation on red from GM for the camaro.
Thanks again everybody, gotta love the quick responses on here.
Old Sep 16, 2005 | 08:02 AM
TechCam97's Avatar
Yea, there were only two shades I believe. One was marroonish and was called Patriotic Red and the other was ours which was Bright Red.
Old Sep 16, 2005 | 01:23 PM
tfs95z28's Avatar
Ok, then why does this company Spoiler Depot use the code "81" for the bright red instead of GM's actual code?
So when i order one, should i type in "U8774" or should I use their code "81"???
Old Sep 16, 2005 | 02:02 PM
TechCam97's Avatar
I'd ask them first. GM uses the 4 digit code, so you're better safe than sorry.
Old Sep 16, 2005 | 02:57 PM
tfs95z28's Avatar
sounds good to me... will do.
Thanks TechCam97
k1996z28
Apr 13, 2015 06:54 PM
Jubjub
Mar 19, 2015 10:23 AM
bernie1951
Dec 10, 2014 10:03 AM
Dec 1, 2014 08:08 AM
91Bird305
Aug 5, 2002 01:39 PM
