Clear Corner Install?????
Old Jan 13, 2003 | 01:30 PM
jare23's Avatar
i just got in my clear corners and really have no clue on how to replace the stock ones. anyone have tips or instructions? or if there is a website that shows how to replace them. any help would be appreciated. thanks,
Old Jan 13, 2003 | 02:29 PM
White30th's Avatar
Re: Clear Corner Install?????
Its really not that tough. You have to jack the car up just a little bit so you have enough room to work with. Underneath ther car, right buy the front tires there are two bolts that hold on what look like a flap. Remove those and the flap will fall open. Now you have access to the lenses from inside. since you wont be able to look at what you are doing, you have to reach your arm in there and find all three of the little bolts that hold the lens to the bumper. I dont remember what size the head of the bolts are, but the are pretty small, so it will take a couple tries with sockets to find one that fits. Remove the three bolts at the lens lifts right out. Thats about it, just repeat for the other side.
Old Jan 13, 2003 | 02:33 PM
Brent94Z's Avatar
Super Moderator
I've got pictures of that area and how to get to it on my alarm install page. Check out the section where it talks about mounting the siren and you'll have everything you need with pictures
http://www.bfranker.badz28.com/fbody/alarm96up1.htm
Old Jan 13, 2003 | 06:10 PM
Maro98's Avatar
You can do it from under like that but the way I did it and I think the easiest way is to just take the headlights out and you can see what your doing from the top.
Old Jan 13, 2003 | 07:08 PM
White30th's Avatar
Cant do that on LT1's, headlights are way different.
Old Jan 13, 2003 | 09:24 PM
jare23's Avatar
thanks
i appreciate all the replies. the lights turned out great. thanks.
Old Jan 13, 2003 | 10:55 PM
chesee48's Avatar
good to hear!
where are the pics now???
Old Jan 14, 2003 | 08:21 AM
jare23's Avatar
see what i can do
ill try to see what i can do. maybe even have somee up in an hour or so.
Old Jan 14, 2003 | 10:37 PM
stangkilla1's Avatar
thanks for the info. I jut ordered mine from procarparts.com and been hearing that the install was hard to do, but a flap and three bolts? I can handle that!!
Old Jan 15, 2003 | 12:19 AM
OctaneZ28's Avatar
Disciple
I also just ordered clear corners from procarparts.com via Ebay. Beofre this all I heard about installing them was to take off the entire front bumper!
This way sounds better.
Old Jan 15, 2003 | 10:29 PM
jare23's Avatar
well i was gonna put up the pics but i realized the mi padre had taken the digi cam on a business trip so im gonna have to wait until about friday or saturday to get them on here.
Stangkilla--- i as well ordered my clear corners from procarparts.com, and about the bolts. i found it easier to take off the whole front left and right underbody. it was a total of 14 bolts(7left & 7 right) then a little work getting out the plastic cover. from there its just the basics, looking and seeing what to do. very easy. good luck!
brandboZ28
Jan 31, 2003 06:19 PM
silver97Z
Sep 11, 2002 03:17 PM
AW/whiteZ-28
Aug 27, 2002 12:53 AM
AW/whiteZ-28
Aug 22, 2002 11:53 PM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
