Clear Corner Install
Old Jan 7, 2005 | 06:49 PM
97Z2830thAnn's Avatar
Hello, i have a 1997 Camaro Z28. I just bought clear corners (ebay). And i am having a hard time installing these lights. I took every screw out of the bottom of the car. But another question is do you think i need to take out that bottoming out guard? Advise would be greatly appreciated! Thanks
Old Jan 7, 2005 | 07:06 PM
6SpdLT1Z's Avatar
Re: Clear Corner Install
What bottom guard? The spoiler that shoots the air up into the radiator? That needs to come off, I believe its a 10mm or 8mm... Then both of thoose side pieces need to come off... Then you can get under it, unbolt your turn signals and replace them with your new ones. There's another thread on this where Brent posted a link that showed how to get thoose side pieces off.
Good Luck, it was a easy install for me.
Old Jan 7, 2005 | 07:13 PM
The bottoming out guard us camaros have so we dont bottom out. The huge plastic piece that is on the front of the car.
Old Jan 7, 2005 | 07:39 PM
6SpdLT1Z's Avatar
There should be about 8 bolts holding it to the car from the front. Maybe it's different on a 97, don't know.
Old Jan 7, 2005 | 10:28 PM
Z28Nut's Avatar
It's an air dam to direct air flowing under the nose up into the radiator. They just happen to work well as a bottom out notifier, too.
Make sure you put this back on or the engine may overheat.
brandboZ28
Jan 31, 2003 06:19 PM
silver97Z
Sep 11, 2002 03:17 PM
AW/whiteZ-28
Aug 27, 2002 12:53 AM
AW/whiteZ-28
Aug 22, 2002 11:53 PM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
