Body Kit tape?
Old Mar 5, 2005 | 12:07 AM
blackz151's Avatar
Body Kit tape?
Ok car sat in the sun for a few dayz at work. and now all the tape melted the body kit looks soo have a$$ its sad. But i rip it all off and get rid of it . What is the best stuff to use to get it stuck back on there good?
Old Mar 5, 2005 | 08:33 AM
Brent94Z's Avatar
Super Moderator
Re: Body Kit tape?
3M double sided tape. Installed on my body kit in 97/98 and it is still stuck like glue. The tape is the primary means for holding the body kit on too... very few screws and they are just used on the "ends".
Old Mar 5, 2005 | 09:36 AM
97FormulaWS-6's Avatar
Re: Body Kit tape?
Yup, look for the Grey tape with the red peel-off. Clean both surfaces with alcohol or prep-sol before you use the tape. Then apply the tape to the item to be stuck to the car. Press down and make sure the bond is good between the tape and item. Trim the tape as necessary if doing emblems or similar. Then use a hairdryer or heat-gun and warm the tape until the red peel-off begins to lift and crincle. Then peal the red off, and apply the item to the car; start with very very light pressure, and then once it's in place, then press hard and be sure the tape has fully bonded with the car.
This is how they do it professionally at collision shops.
CARiD
Feb 9, 2015 09:35 AM
CARiD
Jan 14, 2015 04:00 AM
rockync7
Jan 1, 2015 05:10 AM
CARiD
Dec 26, 2014 04:20 AM
RedLineRev
Jan 23, 2003 03:51 PM
