Body kit installation tips?
Gonna try to install a body kit on my 99 camaro. Anyone have any tips?
Do i need to paint the pieces before i put them on my car?
Anyone ever install an "Extreme Dynamics, Sniper" bodykit before?
Re: Body kit installation tips?
I installed GE's on my 85 Bird.
Fit the pieces on there first, mount all/ if any brackets, drill all mounting holes first. Make sure it fits right, then take it down to be painted. You can use some clear silicone to seal the drilled holes, to prevent rust. Or use a type of brush on primer w/ a small brush to hit the bare metal. You can stuck the bolts in the silicone tube to get some on there, then sink em home. (after kit is painted)
Cool very helpful. Thank you.
Do body kits usually come with the templates to drill the holes?
Wow that is awesome work man. I read all of your thread and a ton of good info. If i decide to press my luck and go for the Sniper kit i will not be molding it at all. That's too much work for me, at least in the beginning. Maybe later, like next spring or something.
I've got a 99 camaro, so i'm wondering if the issues you described with fitment have been fixed in the newer Sniper kit. Honestly all this work is putting me off from trying this myself. It would only be myself doing all this work and i don't have much experience with body work.
The issues i can forsee problems with doing this myself is the rear bumper, fabrication and cutting/trimming the front passenger side bumper. Those things you already described.
How are you going to put in the turn signals? Are you going to cut a hole in the front or side? Its strange that they didn't include holes for the signals.
Thanks, very very helpful.
the hood is easy. just 4 bolts for the henges and 4 for the numatic shocks.
Ill have to find my post on the turn signals. What i wound up doing is drilling 12 5mm holes and installing super bright orange leds. I wouldnt reccomend dooing this as it is highly illegal but my car is a show/strip car and will rarely see road time. Even if you could get a family member to just hold the bumper in place so you can libe up the mounting bracke and mark were you need the holes on both to line up at. then you could remove the bumper and drill the new holes in the bracket and the bumper and pop rivet them in.
The front bumper is held in by the stock mounting locations by the fenders and i used abour 6 self tapping screws along the part by the radiator to secure it there. Where i had to cut the bumper on the passengers side i fiberglassed it in from the back and spent maby 20 hours total on just that peice. hopefully the ls1 style like you have wont be off.
The side skirts are hels on by counter sunk rivits on each end (4 per end) but the middle of the side skirts is so off that there is about a 1.5" gap about 1 foot from the front end going to the back. I just glassed there to cover up the gap and then smothed out with a 50/50 mix of bondo and resin.
You will also have to spend some time block sanding/filling both bumpers. The mold must have been verry wavy or not preped well as they looked like the ocean on a windy day.
If they ship it through freight with overnight express besure to thuroghly inspect each and every peice for damage. My hood and corner on the drivers side skirt were damaged and i had to wait on them to cut a check for it so i could order new peices. What are they asking price wise? I only paid 1200 for the complete kit and hood and hood pins and some wire mesh for the grill area. You can talk them down a bit on the price if you call them.
heres the tail light thread. Rember i do not reccomend doing this as it ishighly illegal. I imagine the fine is pretty steep. if you do it i hold no responsibility for your tickets.
http://web.camaross.com/forums/showthread.php?t=423660
edman
Jan 22, 2015 02:45 PM
CARiD
Jan 14, 2015 04:00 AM
CARiD
Dec 26, 2014 04:20 AM
