Best reverse indiglo guages?
Originally posted by chesee48
I perseonally dont know of any that doesnt require the removal of the needles. Sucks, but thats what everyone i know has had to do. Take your time and you should be fine.
good luck.
good luck.
Originally posted by Snoman73
Then how do i do it, the best way? for for best results? also which ones are the best? i seen some good lookin ones on ebay, anybody tried those?
Well, you have to carefully make sure that you dont break them. Make sure that your have an EXACT writen down measurement on where the needles were before u pulled them off. When i did mine, you Dont have to pull off ALL of them, but most of them in order to get it to fit. Then u can just slide it in and use a lil tape to make it stick to the back of it. Wire it, basic wiring and you should be all set. Like i said, if u take your time, its a fairly easy job. Just be carefully and you'll be ok.
Re: Best reverse indiglo guages?
ive seen some on ebay, i want the best ones and ones that dont require removal of needles, which ones are they? thanks
Re: Re: Best reverse indiglo guages?
Originally posted by pu12en12g
Just replace the 194-Type bulbs in your dash with 194-type LEDS of whatever color you want.
I'm making mine blue I'm gonna order them as soon as my friend pays me back 40 bucks
You cant mean to tell me all you guys dont know how to install these gauges!
So you pull of your needles and screw your dash up?
For anyone interested, once you have your gauges out and disasembled. Start with the two long needles first - once the gauge kit is over them then slide it over the two small needle on one side being careful not to bend the kit too much - once you have it over them go on to the last two small needles and your done! No need to screw up the accuracy of your gauges by pulling off the needles!
go to procarparts.com. They have them. They usually have a few sets on ebay. I got mine form ebay for $30. I personally think they are awesome for $30...
There are a day and night pic on my site here:
http://www.fbodypages.com/joe/pics.htm
Re: You have got to be Kidding!
Hey...if anyone wants a set of those G2 reverse indiglo guages that JxxxOxxxE has, I have a spare kit still new in the box that I'll sell. I somehow ended up with 2 sets, and only needed one. Just PM me.
-Mike
-Mike
RUENUF
Mar 13, 2016 03:37 PM
