? about eclipse door
Old Jul 9, 2004 | 06:49 AM
Newbie97's Avatar
I finally got it installed but I didnt use the inner plastic or drip can or what ever you call it.. back on. I didnt see how it would fit and install the door with a good fit because using just the two screws and fender washers didnt give it a real tight fit. It was loose and would flop a little when I opened the door so I used all four bolts with washers. I had to drill them out too so the bolt would go through and I use the nut also for more secure fit. Will it be ok with the inner part out or do I need to find a way to make it fit. It doesnt look bad till Im pumping gas but Im the only one that knows. If its ok Im leaving it because I like the secure fit I done.
Aaront810
Aug 29, 2020 09:34 PM
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
z28cam1993
Sep 9, 2015 04:08 AM
