94 Z28 door removal?
Ok...I know how to take the door off...my question is...how the hell do I get the wiring out? I bought a used door and the dude just cut the wiring from the old door...so not sure how it all comes out.
Hook a brotha up.
James
Hook a brotha up.
James
I sure if you unhook everything ! in the door all the wiring will pull out throught the whole in the door where the rubber boot is then just reverse the process to put it back in the new door
Unhook whatever power connections you may have and pull the door panel off the door. The wiring harness will be held in place by plastic clips, I believe. Just pop those out and pull it through the rubber boot at teh front of the door.
Patricklt1
Apr 24, 2015 06:29 AM
