94 Shift Knob Question
Old Sep 22, 2004 | 11:39 AM
9428Green's Avatar
94 Shift **** Question
Does anyone know how to remove the stock shift **** on a 94 auto Z28? I found replacements for them on an F-Body site, that have "Z28" engraved in it, and i was thinking about buying one, but i can't figure out how to remove the stock one. Thanks in advance!
Old Sep 22, 2004 | 12:20 PM
detroit1994z28's Avatar
Re: 94 Shift **** Question
There is a c clip in the front of the **** that you cannot see. With the car on, and your foot on the brake, drop it all the way in 1st or 2nd. Needle nose pliers is all you need to get that clip off. Pull the **** off, re-install new **** the same way. Simple install. - Hope that helps you - Mike
Old Sep 22, 2004 | 01:49 PM
Tair's Avatar
yup it's simple to replace, just pop out the c-clip. You may have to give the clip a small tap with a hammer if it won't go back in after putting on the new shiftknob.....but only a small tappity tap tap....just a small tap-eroo.
Old Sep 22, 2004 | 08:33 PM
Bud M's Avatar
Don't forget the search, this is one of those questions that has been asked a thousand times.
RUENUF
Mar 13, 2016 03:39 PM
jb4xx
Feb 2, 2015 10:00 PM
Jason Short
Jan 19, 2015 06:34 PM
cmdeshon
Dec 27, 2014 10:06 AM
redz_02
Jul 24, 2002 09:42 AM
