1996 Camaro convertible top not moving
Old May 23, 2020 | 06:57 PM
  #16
Re: 1996 Camaro convertible top not moving
SAE 10W is a single viscosity oil. Not the same as 10W-30 multi-viscosity oil.
Old May 23, 2020 | 10:53 PM
  #17
squarehead's Avatar
Hi Darkheart,
I am sorry to be late to the party but it sounds like you are in good hands. You are getting the pump to run so you don't have an electrical problem but probably do have a hydraulic leak. I don't have any experience tracing the hydraulic lines for leaks as my car always held fluid and I never had to top it up. I do know from working on hydraulic gate operators (my trade) that once you add oil to a system it can take many cycles before the fluid displaces the air that infiltrated the system when the fluid leaked out. I would keep adding oil after each few cycles and see if you can get the unit to fully function then start looking for the oil leaks!
Good luck!
Brad Back
May 9, 2016 09:41 PM
kallcium
Sep 26, 2015 03:58 PM
z28greenhorn_29
Sep 28, 2012 01:49 AM
trueflex
Jun 22, 2011 07:03 PM
jdelaprida
Jan 31, 2011 11:55 AM
