Yes, there is such a thing as a cam that is too big!
Re: Yes, there is such a thing as a cam that is too big!
Originally Posted by rskrause
"bad" cams = 228/244 @ 0.050" 114LSA
"good" cams = 222/224 on a 116
Rich
Rich
Rich,
You sure the bad cams were not the Stage 4 Crower cams 62825-4
At the Valve
236° Intake
244° Exhaust
At the Lobe
220° Intake
228° Exhaust
Did you switch over to the Comp XE258BH-116?
That one is a lot smaller than it lists.
At the valve
222° Intake
224° Exhaust
at the lobe that's around
206° Intake
208° Exhaust
Bret
Originally Posted by SStrokerAce
Rich,
At the Valve
236° Intake
244° Exhaust
At the Lobe
220° Intake
228° Exhaust
At the valve
222° Intake
224° Exhaust
206° Intake
208° Exhaust
Bret
At the Valve
236° Intake
244° Exhaust
At the Lobe
220° Intake
228° Exhaust
At the valve
222° Intake
224° Exhaust
206° Intake
208° Exhaust
Bret
Rich
Thanks Rich.
I've been looking at these motors closer and I did a little diging to find out what the deal is. Nothing wrong with the Crower stuff at all, in fact they have 4V lobes that are a lot less aggressive than the Comp ones. Crower even had a good set of cams for that setup that would have worked as well as the Comp set you guys ended up running.
Bret
Bret
armedtrigger
Feb 24, 2015 08:30 PM
Hal Fisher
Sep 14, 2002 09:36 PM
