Yes, there is such a thing as a cam that is too big!
Old Apr 20, 2006 | 03:48 PM
  #16
sssalah's Avatar
Re: Yes, there is such a thing as a cam that is too big!
Originally Posted by Gun5
i dunno my car drives ok on the street with the 290 cam.. i havnt driven it that much on the street cuz its not insured yet but it drives ok and when u put that pedal down instant throttle response cam makes its stuff at 6200 where my shift point is
you guys think there is another cam for my app that might be alittle more streetable (not complainin on how it is now though)?? guy i bought the car from was making a drag car but i bought it to put on the street and be my daily warrior
That 290 is seat duration, your cam is 230 @ 0.05".
Old Apr 20, 2006 | 08:39 PM
  #17
1racerdude's Avatar
Rich,
The cam's weren't too big,the RPM's were too low.
Put a 5/1 gear in it and watch out.(JOKE)
We are shifting(glide) at 9,500 with 26PSI and running 8.90-9.20 in a 3100lb 'stang with 12x33's. That's with 281CID-no stroker.
Old Apr 20, 2006 | 10:03 PM
  #18
marshall93z's Avatar
What class is that with a tire size like that?
Old Apr 20, 2006 | 10:06 PM
  #19
1racerdude's Avatar
Fun Ford Open Comp. They will/have put it on the bumper leaving at 5500 on the brake,on the stutter box and foot on the floor. It builds boost nice like that.
Old Apr 20, 2006 | 11:18 PM
  #20
rskrause's Avatar
Moderator
Originally Posted by 1racerdude
Rich,
It did run fine above ~3,500rpm, I'll admit.
Rich
Old Apr 21, 2006 | 07:36 AM
  #21
LameRandomName's Avatar
Rich,
The cam's weren't too big,the RPM's were too low..
And I'm not fat, I'm just short for my weight.
Old Apr 21, 2006 | 02:31 PM
  #22
Old Apr 22, 2006 | 09:47 PM
  #23
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Yep, I often run into this same thing.
Somebody wants the biggest cam in the world and expects it to drive like stock and doesn't have the cubes/compression/converter/gearing to match it.
Old Apr 23, 2006 | 02:16 PM
  #24
FastZinTennessee's Avatar
Originally Posted by rskrause
The car in question made ~670rwhp with stock heads and bottom end and
<20psi. As to how long it holds together with a stock bottom end, that's another question altogether.
Rich
I knew a guy who spiked 22 psi on a stock '96 4.6 DOHC motor. What we thought was an exhaust leaked from the exhaust actually turned out to be an exhaust leak between the block and head The headgaskets had been blown out where the bore gets closest to the edge of the block on 7 out of 8 cylinders.
Old Apr 23, 2006 | 09:10 PM
  #25
Old Apr 29, 2006 | 04:45 PM
  #26
scarface007's Avatar
all serious builders build their motors around the cam not the cam around the motor.just my .02
Old Apr 29, 2006 | 05:24 PM
  #27
OldSStroker's Avatar
I hope you meant the opposite to that.
Old Apr 29, 2006 | 06:59 PM
  #28
rskrause's Avatar
Moderator
I'm usre he's liek me, a littel lysdexic.
Rich
Old Apr 29, 2006 | 10:51 PM
  #29
1racerdude's Avatar
If ya build everything around your heads it will run a lot better.
Old Apr 29, 2006 | 11:17 PM
  #30
96speed's Avatar
I bought a cam from a guy once. I filled out his form and it came through the mail. I installed it and it hit the rods. He told me to pull the motor and grind the rods.
Ryan
