Wiring questions...???
Hello,
I'm trying to wire up speedp gauge on my car... but I can't get a good signal off of the speed sensor in the Tranny.... is there a way I can tap into the Speed sensor at the PCM???? anyone know the wires????
Re: Wiring questions...???
This really isn't advanced tech content, but it would help if you described exactly what sort of gauge are you trying to wire up? Stock, aftermarket? If aftermarket, what type? Is it configurable?
It's a digital speedometer that has a wire that needs to be affixed to the speed sensor on the transmission... for some reason I can't get a good signal... even with shielded cable. I was trying to see I I could directly route that wire to the speed sensor wire on the PCM... if there is one...??? I also was trying to see if maybe there is some sort of signal booster to use... to fix the issue as an alternate way... isntead of hacking up wires.
surreybrad
Apr 22, 2015 06:40 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Madwolf
